Old 02-26-2022, 03:53 PM
Kodiak351 Kodiak351 is offline
Default IH Cub Cadet 129 Replacement Motor
Howdy! I have an old International Harvester 129; have had it maybe 4 years, now. The motor recently blew on me- looks like the rod broke and went right through the side. I don't think it's the original motor- it's a Tecumseh 10hp- and I'd like to replace it. I've had no success finding another Tecumseh, except for a few online that have tapered shafts (mine is not tapered), but I have been looking at the Predator 13hp motors ($399, and that's already beyond my budget) that Harbor Freight carries. Has anyone ever used this motor in a 129? I mainly worry about the baseplate dimensions, but maybe there are some other factors I need to consider that I have not thought of yet. I'll still have to get crank length and dimensions from the old motor, too, but I'm on the road for another few weeks. Any help in information would be very helpful! Thank you!
Old 02-26-2022, 05:49 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
I'd think somebody would be by to tell you better but
It should have a 12hp Kohler K301A, 1 cyl engine.
I would not bother with a Chinese engine (predator)
If I couldn't find another 12hp Kohler, I'd look for a newer Kohler Command 1cyl, from like a 2130 to 2166.
I've never done this swap but it shouldn't be that hard.
JD x475
Old 02-26-2022, 11:11 PM
Farmall450's Avatar
It should have a 12hp kohler K301a, 1 cyl engine.
If i couldn't find another 12hp kohler I'd look for a newer command 1cyl from like a 2130 to 2166.
The predator motor (and most Honda clones) are actually pretty good. However, I agree with above -- you can find a sound used Kohler K301 or similar for less than $400. Probably closer to $100.
Old 03-01-2022, 01:43 AM
Thank you for all the replies. I accidently stuck this in the Kohler engine section, and don't know how to change it, so, oh well. Does anyone know where I could find one of the proper Kohler motors? Time will be short to get a motor in our tractor. It has a lot of tilling to do as soon as the earth thaws!
Old 03-01-2022, 09:20 PM
aagitch's Avatar
aagitch aagitch is offline
Advertise in the classified section here and there is also some good bookface cub cadet groups you can post in. There should be plenty available.
Adrian
2072 (789513)
Old 03-01-2022, 10:18 PM
Farmall450's Avatar
******** Marketplace, Craigslist too.
Old 03-02-2022, 12:01 PM
jcubtroy's Avatar
jcubtroy jcubtroy is offline
Yanmar Diesel could be a nice upgrade.
Old 03-02-2022, 11:17 PM
Farmall450's Avatar
Probably not on that tractor without side panels/air ducting.
Old 03-05-2022, 01:02 PM
Thanks for everyone's help- I put up an ad in the "wanted" section.
