Old 05-16-2022, 12:00 AM
rodtrac rodtrac is offline
Default Rims
I understand that to measure the width of a tire rim you are to take the measurement from the inside bead of one side to the other. Now the question my tractor has 4.80x4.00x8 tires and they are mounted on IH rims that measure 8 inches by 2.5 inches wide. ( inside bead to inside bead). The measurement from the outside rim to the other side is 3 inches. All reading material I have seen references rims for this size tire measure 3.75 x 8. Can anyone shed any light on the 2.5 inch rims? They were original to the tractor when my father bought it in 1967.
Thanks
Old 05-16-2022, 07:17 AM
First, welcome to OCC........
What Cub Cadet tractor model are you talking about?
Old 05-17-2022, 09:13 AM
Default Answer
Model 122 Cub Cadet Mfg. 1967
Old 05-17-2022, 09:36 AM
The 122 rolled out of the Factory with these front rims:
IH-386188-R92 Wheel Assy, Front w/3.75 X 8 Rim for 4.80/4.00 X 8 Tires .
I can not find where IH used a 2.50" rim.
Old 05-17-2022, 02:14 PM
Default Interesting
Thank you for that information. That is what I found also. I would like to post a picture of the rim but can't seem to find instruction on how to do that.
Can you point me in the right direction on how to post picture? The tires on the tractor are the original goodyear 4.800x4.99x8 tires. The rims have a grease fitting into the bearing seats. Don't look like they were added later. They look factory installed.
thanks,
Old 05-17-2022, 02:15 PM
Default correction
meant to say tires are 4.8x4.00x8 typed 99 by mistake
Old 05-17-2022, 03:07 PM
Default picture
picture of the odd rim from 122 CD
