Hey I’ve got a 1979 1450 hydro. I had a couple oil leaks I fixed over the winter, had the engine out to do it but now I’ve cut the grass I seem to be burning oil. Seems like it burns 1/2- 3/4 liter(quart) per 2-3hours of cutting. It doesn’t smoke or anything which I think is odd. I thought I’d be able to see it in the exhaust but I can’t. What would be my next go to? Re doing the top end? And if so is it fairly straight forward? I have a decent knowledge which 2 strokes have done a handful of top end 2 strokes but nothing 4 stroke. Is it similar? Are valves easy enough to figure out?
Thanks for the help |
Oil consumption is in usually in these areas. (A) The Piston Rings, and/or (B) the Valve Guides.
It is a straight forward process, and as you would expect, it is engine tear down. There is a Kohler Engine Service Manual (K Series) in the Technical Library Section, for download to aid in your repairs.
That's alot of oil for there not to be smoke. I'd suggest looking it over real good to make sure there isn't a leak.
Pan gasket and or cracked pan
front and rear main seals valve breather gasket(s) there are 2 of 'em Governor shaft bushing (the brass one behind the adjusting lever) Head gasket points push rod All area to keep an eye on. |
