Old 10-27-2022, 10:23 PM
djrober djrober is offline
Default Kohler M18 Carburetor
Has anyone had a good or bad experience with replacement carburetors? I am looking online and have a hard time believing that any carb under $50 can be good.
Old 10-27-2022, 11:14 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Thumbs up
I've used one of them on my 1989 1050 with the Kohler Magnum 10. The original carb was a Walbro fixed jet. It had wear on the main throttle shaft, so the engine would have a lean misfire at high speed. The new fully adjustable carb completely fixed the misfire, and does the job quite well.
Old 10-27-2022, 11:51 PM
Thanks for the feedback. Any specific brand/distributor?
Old 10-28-2022, 06:54 AM
Personally, I would stay away from the cheap Chinese knock offs. I would tend to buy a Kohler Adjustable Carb, followed by a Walbro Adjustable Carb.
Old 10-28-2022, 07:16 AM
Oak Oak is online now
I picked up a 1711 with a destroyed carb and purchased one of those pos $16 carbs off of Ebay. It actually ran great but I sold it soon after so I don't know how long they hold up.
Old 10-28-2022, 10:51 AM
I will look into see where I can purchase OEM. Has anyone worked with iSaveTractors (https://isavetractors.com/)? They sell an adjustable replacement for $70.
Old 10-28-2022, 11:54 AM
Default Those are not oem, same 15.00 carb just they change the shoke and throttle shafts to
Those are not oem, same 15.00 carb, just they change the choke and throttle shafts to accommodate the the engine it is going on.
I do not think the china carbs come in a different grade, good, better, best.
Old 10-28-2022, 03:16 PM
I think I had to remove the old choke shaft and plate and install in the new carb. Unless you wanna spend probably $100+ on a used one go for the Chinese special for $20. Can’t even get a 30 pack of Bush Light for that.
Old 10-29-2022, 06:35 AM
1711Cub's Avatar
Thumbs up
I purchased mine from Amazon for under $30. I did have to replace the choke shaft from the original carb, but other than that, plug and play, and obviously adjust the idle speed and both high speed and idle mixture.
