Old 06-07-2023, 08:30 AM
Default 2072 Power Steering
I am going to tackle a Power Steering problem on the 2072. I have never done a job like this. The Ross Gear HGF series of unit, has a #SK000097 Seal Kit. In doing some research, there is a Company called Midwest Steering in Independence, MO, that is suppose to be a Ross (Parker/TRW) authorized Servicer/Supplier. In doing an internet search, I see the price of this kit greatly varies. I have seen an attractive price on Amazon, but I don't know if it is a genuine kit, or a Chinese knockoff.
Looking for guidance, suggestions, input, or recommendations, on this kit.
UPDATE: @ 10:20am
Contacted the Amazon Seller and he states, it is a "premium aftermarket" kit.
Old 06-08-2023, 07:12 AM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
My advice is to make life easier on yourself, remove the power steering unit and take it to a shop that rebuilds hydraulic cylinders. It will be done right the first time and it will not be terribly expensive or difficult for the rebuild shop
Old 06-08-2023, 07:21 AM
That may be a tad difficult for my neck of the woods.
Old 06-08-2023, 07:42 AM
zilla24's Avatar
zilla24 zilla24 is offline
I'm interested in this project, I'll be tagging along as my 1572 power steering is leaking quite a bit.
CC Tractors: 1650, 1200, 800, 149, 125, 86, 782D, 2072, 1572, Original
Old 06-08-2023, 07:51 AM
I did my 1772 10 years ago and it has been trouble free.
https://www.onlycubcadets.net/forum/...ad.php?t=50629
These are pretty easy to do if done properly. Make the holding jig that is in the manual. Steiner/Ventrac use the same steering box and their parts are cheaper.
These kits are the same from what I hear.
Deere -- AM107078
Parker -- SK000097
Steiner -- 21-SK000011
Here is the kit I used.
https://www.messicks.com/part/21-SK000011
Here is the spring kit just in case they go flying across the room.
https://www.messicks.com/part/21-401443x1/spring-a
Roland, is your unit leaking or not working properly?
Old 06-08-2023, 08:48 AM
The steering "wanders" and one has to make 1-1.5 turns to correct it. No leaks and turns eventually.
Old 06-08-2023, 08:50 AM
That sounds like the cylinder is leaking internally. Have you checked that yet?
Old 06-08-2023, 09:11 AM
No, I haven't. I just assumed it was in the Ross Gear Power unit.
Old 06-09-2023, 07:30 AM
dale c. dale c. is offline
replace the cylinder , i had the same problem a few years ago on a 1882 and the cylinder fixed it.
Old 06-10-2023, 07:50 AM
Been busier than a cat on a hot tin roof lately (A/C work ). Hopefully I will have sometime this weekend, to look into it.
