Old 07-31-2023, 03:18 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Default Unsure if tapered shaft will work for me
Hey all. Sorry for my ignorance, but will this short block off eBay work for my IH Cub Cadet 70? I didn’t know the term tapered shaft. Thanks in advance.
https://www.ebay.com/itm/38576327483...Cclp%3A2349624
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 08-01-2023, 08:01 AM
The tapered shaft is the end that secures the flywheel, a tapered friction fit w/a keyway
What is wrong with the engine that's in your 70?
Buying that one off e-bay would be a crap shoot and may turn out to be a boat anchor.
Old 08-01-2023, 10:46 AM
ironman's Avatar
ironman ironman is online now
You need a crankshaft with the PTO end like the K161 crank pictured.
You can see that his looks nothing like it.
Move on....
Old 08-01-2023, 02:03 PM
LAWN BOY's Avatar
Thanks for the replies!
Finruskuw, the one that is in my 70 right now idles high and makes flames in the muffler. I will be checking valve tappet clearance before actually rebuilding the engine or buying a different short block or engine.
Old 08-01-2023, 05:34 PM
Sounds like a lean carb problem.
Old 08-01-2023, 07:06 PM
Do a thorough tune-up.
New plug and points, make sure the condenser is good.
Adjust the governor, put a kit in the carb paying close att'n to the float setting and static time the engine as well.
May just solve your problem.
