Old 08-30-2010, 10:00 AM
rollsroyce1999's Avatar
rollsroyce1999 rollsroyce1999 is offline
Default Sleeve Hitch Question
I am looking to get a Sleeve hitch setup for my IH built 782.
My question is the cast lift arm the same for all tractors (both wide and narrow frame)? I understand that the rod which goes from the hydraulic cylinder to the cast piece varies (some are straight and some have a bend), but is the cast iron piece itself universal for all tractors or do I need one specific to the wide frame tractors?
http://ccspecialties.org/WFNOScasting.jpg
Also, Is the lower lift bracket universal?
http://t1.gstatic.com/images?q=tbn:2...Hitch4.jpg&t=1
Thanks for your help.
Old 08-30-2010, 10:35 AM
ihnick's Avatar
ihnick ihnick is offline
Lower bracket is universal. The top cast piece you need one for a wide frame only and the rod from that to your rock shaft needs to be for a 82 series
Nick.
Old 08-30-2010, 10:42 AM
More specifically, the lift bar needs to be for a 782. The manual lift tractors have a radically different lift bar.
Old 08-30-2010, 11:02 AM
So,,,,,
The cast part (photo below) must be from any wide-frame such as 1450, 682, 782, 982, 1811,,etc.
The lift arm needs to be from a wide frame (obviously hydro-lift) tractor. Is the lift arm from a Super the same?
http://ihccw.com/IMG_4571_3.JPG
The lower lift bracket is universal across both wide-frame and older tractors.
http://t0.gstatic.com/images?q=tbn:P...p7x/CC.jpg&t=1
Old 08-31-2010, 12:10 PM
kwduffy's Avatar
kwduffy kwduffy is offline
The lift arm needs to be specific to a 782, a lift arm from a 782 and from say a 1200 are going to be different because of the way the 782 has to be hooked up. Perhaps someone has a picture but I believe the 782's lift bar is straight where as a normal WF lift bar has the bend in it like the one you linked.
