Hi Folks. I need a battery for my Model 1863 Cub Cadet. What replacement is suitable ? Thans for any suggestions
![]() Thank You all, for the great advice ![]() |
The original is a 26R. Not sure what else will fit.
I use U1 lawn and garden batteries from Walmart in my 1641 and 1863. They might not work as well in the north but do alright in GA.
Cannon |
The 26R battery is the right size with the top terminals reversed for proper orientation (negative closest to firewall and terminals on the left side). You can get a 525 cca battery at Walmart or Runnings for about $80.
Car batteries make good replacements if the right size. If it poops out in a tractor, it’s not as much of a problem as with a car.. If you use a trickle charger when the tractor is not being used, your battery will last a long time. I had one last for nearly 20 years because I religiously looked after it. Be sure to use a battery tray and secure the battery with the clamp on the bottom to avoid leakage. Use a maintenance free type battery. ![]() |
![]() Quote:
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Good deal! Anything that is a close fit will work just fine!
