my 2182 throws the temp light on dash after about 20 mins of run time. i always shut down quickly and let it cool. It has never boiled over and wonder if it could be a faulty temp switch. I would just replace it but that switch is no longer available. Any aftermarket part # that would cross reference?
It also makes me wonder if you have faulty thermostat, water pump or clogged cooling system. Is the radiator hot after 20 minutes?
Without knowing your serial #, for a switch on the earlier models there seems to be many hits for a temp switch. Verify before buy: https://www.fridayparts.com/temperat...IaAjulEALw_wcB
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Cooling on the 2182 and the 1782 is marginal at best. Check everything T stat, pump, radiator and screen. I put a temp gauge in my water pumpers and I also added Red Line water wetter to the coolant, you can get it at most auto parts stores.
