Old 06-14-2025, 04:38 PM
jeriffe jeriffe is offline
Default Cub Cadet XT1
I have a Cub Cadet XT1 LT46 riding mower. It has a Tuff Torq TL-200 transmission. I noticed a few weeks ago that when the mower is off, I can roll it with the hydro bypass rod engaged and disengaged. I also noticed that while driving when I left off the hydrostatic pedal, the mower continues to move as if it's not returning to neutral and is creeping. This is more noticeable when letting off the forward pedal compared to reverse. I've jacked the rear up and it does the same thing.
The bypass rod is moving as it should and appears to be engaging but it's apparently not. I've worked it several times, lubricated it, and tapped it lightly with a wooden dowel/mallet. Under the mower, all plastic clips are in place, none of the linkage or arms appears to be bent. There is no grass or obstructions. The dampener appears to be functioning properly. It doesn't appear that I can adjust anything to return it back to true neutral.
Any suggestions?
