Old 10-15-2010, 08:32 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Default Blew up my 1200 tonight...bummer!
Got home and decided to move things around in my garage. I wanted to move my 73 GS and put my 41 JD H by my tool boxes so I could remove the brakes. I had to put the battery in the 1200 to move it.I checked the oil and started the tractor and drove it outside to run and let the battery charge a little.It was idling and sitting right outside of the garage when all of the sudden it made a bang and sounded like it remained running for a good 12-15 seconds then shut off. I pulled the plug and turned it over and had no compression. I am betting the big end of the rod went. It currently has a 14 hp motor in it. I guess I'll have to remove the motor and see if just the rod went or what happened...
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 10-15-2010, 10:13 PM
Sorry to hear that, Pat. You'll get it straightened out.
Old 10-15-2010, 10:16 PM
Sorry to hear that bignastyGS
That is a bummer.
Let us know what you find out.
Old 10-15-2010, 11:03 PM
johncub7172's Avatar
Yea, that happens! Sorry, as well. But I'am gonna have somebody here on this fourn rebuild my k161 that, it too, snapped it's little arm. You too may have your motor fixed as well.Keep us posted!
Old 10-16-2010, 12:16 AM
Wow....you seem to be taking that as a good sport. What a disappointment. At least it isn't coming out the side of the engine and it wasn't when you had it out doing work late at night......nothing like having bad luck happen away from home and having to tow it back whileit is dark out!! It will work out in time!!
Old 10-18-2010, 12:26 AM
Bummer Pat keep us updated with your progress.
Old 10-21-2010, 07:06 PM
1811woody's Avatar
Sorry about the motor mishap I have been checking into a rebuild for mine (18 hp magnum) before it blows what an expensive adventure!
Old 10-23-2010, 04:11 PM
bignastyGS's Avatar
Finally got to rip the 14 hp out of my 1200 and found some not so good things...Seems the connecting rod welded itself to the crank and broke into 4-6 pieces but didn't hit any of the block. The 3 pin driver exploded as well so now,I will be installing a good 1250 12 hp motor maybe as soon as tomorrow and getting it back to running. Gonna strip the 14 hp and probably throw away unneeded pieces as we don't have another tractor or spare parts for this motor. The cost would be too much to fix and I don't have the extra to shell out..To think I just changed the oil in this about 3 weeks ago,I guess I should be happy as I got 2 mowing seasons and 1 snow pushing season out of a motor that was in 5-6 boxes of parts we got with a 1450 parts tractor. Wonder how much difference I will feel with 2 less HP?
Pat Harmon
Loganton,Pa
128 Cub Cadet
LT 1042 Cub Cadet
1200 Cub Cadet
1941 John Deere H
Old 10-23-2010, 04:14 PM
Sorry to hear that, At least it didn't tear up the block. Hope you get your other motor in without any problems
Old 10-23-2010, 05:37 PM
ihnick's Avatar
ihnick ihnick is offline
What happened to your original 12 horse
Nick.
