Old 07-28-2025, 03:32 PM
mferris72 mferris72 is offline
Default Hydrostatic pump issues 1872
I have an 1872 that I replaced seal and gaskets. Serviced it with fresh Hy-Tran. Work forward and back, but jerks violently when selected. Anyone know why? I suspect something is worn. The brass pump plates maybe ? I’ve heard you can machine the smooth again.
Old 07-28-2025, 09:24 PM
Are both of your trunion springs good? I had a broken smaller spring and it did that.
Old 07-28-2025, 09:51 PM
CubDieselFan's Avatar
If your trinuion is worn out, Mark at Machtech Direct has a no welding solution.
Old 07-29-2025, 02:33 PM
I replaced both springs and the caps. Bracket is not worn. Anyone know detail about the pump itself? Will it affect/cause this ?
Old 07-29-2025, 08:34 PM
Was it doing this before the seals were changed?
Old 07-29-2025, 08:36 PM
I have never heard this.
Old 07-30-2025, 02:18 PM
Wasn’t jerking g before the seal change, but wasn't real smooth.
