Old 08-05-2025, 01:24 PM
mschel72 mschel72 is offline
Default LT1050 Weird issue PTO circuit?
Hi, we are having a weird issue on a used lt1050. Initially it was a no start issue which was fixed with a new carb and plugs, fuel lines, filter.
Now it runs great except when you start, start cutting, then turn off pto and keep driving. The mower then rpm hunts up and down until pto is engaged again. The reverse mode button does not work either.
Seems like a safety circuit issue but seems like it should be cutting off (?) rather than just rpm hunting?
I did read through this great manual for ltx which seems similar and it seems like maybe its trying to ground out but maybe only killing one cylinder bank or something weird like that (?). The site is not searchable so could not find the lt version.
https://service.mtdproducts.com/Trai...7_electric.pdf
Thanks.
Vintage Models owned (but sold unfortunately!): 100, 102, 105, 125
" Modern" models: LT1050, GT2544, LTX1040 (electric conversion)
Old 08-05-2025, 02:46 PM
ironman's Avatar
ironman ironman is offline
Assume your engine is a CV-730.
For the surge problem, I would suspect a governor sensitivity issue.
Old 08-05-2025, 03:06 PM
Sounds right, I forget the exact engine code. Its the 25hp.
So does the governor kick in or out based on the PTO running? Just confused why it only does this after the pto is turned on then off.
It doesn't do it under load going up a large hill and then on flat (lower load) then downhill with the pto off. Have not messed with the governors before.
Thanks.
Old 08-05-2025, 04:06 PM
ironman's Avatar
The purpose of a governor is to keep engine RPM constant regardless of load.
It is internal to the engine and is always working as long as the engine is running.
If load increases and engine RPM starts to drop, the governor opens the carburetor to give the engine more gas.
And vice versa if load decreases, it closes the carb to prevent engine over rev.
In your case, when you shut off the PTO, the mower load is removed and the governor starts searching for the same engine speed with less throttle but can't get happy.
That is called surging, and correct governor sensitivity eliminates surging.
Little springs on your governor to throttle connection control that sensitivity.
All that being said is with assumption that all other things are correct such as carb settings, ignition, etc.
Old 08-06-2025, 12:35 PM
Just to clarify, are you talking about the tiny little spring that is on the throttle rod? thanks
Old 08-06-2025, 01:35 PM
ironman's Avatar
This may help....
Old 08-06-2025, 01:52 PM
Thanks that makes total sense. Will check it. Might not get to it for a few days. Thanks will let you know.
