Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Rear Engine Rider & ZTR (RER)
Old 06-06-2025, 02:57 PM
jleblanc jleblanc is offline
Default RZT-SX 50 Engine Run Problems
Hi there,
I'm looking for some advice / guidance on troubleshooting my mower. I'm also wondering if my issues are common with other similar mowers.
I have a 2020 RZT-SX 50 with an EFI Cub Cadet engine, model #17AWCBYZ596. It has frequent issues with starting when the engine is cold. When this occurs, the engine also has trouble staying running for the first 5 or so minutes. It feels like a carbureted engine with poor tuning, improper choke setting or fuel starvation. This is a fuel injected model with no individual choke control. When the engine is difficult to start, it will often stall with no warning even after an hour of use. When it stalls like this, it is often very difficult to restart.
Other times, the engine fires right up without issues and works perfectly.
The digital display has never shown any codes. The machine currently has 39 hours and has had these issues since I bought it last year with 27 hours. I initially assumed it had old gas since it would eventually run, but new gas and fuel system cleaner hasn't corrected the problems. The engine also always cranks over, just sometimes doesn't fire up or stalls immediately after firing up.
I've checked the basics like looking for a clogged air filter, clogged gas tank vent, clogged fuel strainer, loose fuel line hose connections, sticky throttle & governor linkages, fouled spark plugs, poor grounds, loose connections but all of those where found to be in good order.
Another issue that may or may not be connected is that the headlight inconsistently strobes when the engine is running. When the engine is off, the headlight stays continuously lit as it should. I've removed the headlight and tested it using a 12V battery and it worked fine. While I was at it, I checked the continuity of the harness and it was also fine. Just to make sure it wasn't a loose connection, I ensured the connections were greased and tight but this didn't fix the issue either.
Any help on resolving this would be greatly appreciated.
Old 07-10-2025, 09:43 AM
Update: The engine won't start.
I continued to use the mower with intermittent starting and stalling issues since I couldn't figure out the issue and needed to mow my lawn.
One day it stalled and now the engine won't crank over. When I press the plastic red key on the push button start ignition module, there's only a faint pulsing/clicking sound coming from the ignition module. No other noises anywhere else and nothing displayed on the ignition module's digital display screen.
So far all these have tested well. Battery, seat switch, PTO switch, EFI relay (tapped below the ignition module), 20A main fuse, all the grounds I could find and confirmed the magnet is still functioning on the plastic red key. Visual inspection of the ignition module's PCB didn't find anything wrong and its relays tested good.
I've also confirmed 12V power going to the correct places, according to the electrical schematic, when the ignition is off. These being the ignition module (one wire on each connector), starter solenoid's hot lead, engine's main 6-pin connector and EFI relay.
Tomorrow I have some time to look at this again and I'm planning to test the parking brake and reverse switches again. They tested good before it completely died but I'll test them again just in case. I'll also keep checking for continuity along each of the safety switch wires.
This now seems like a safety switch communication issue with the ignition module but I'm still not sure. Anyone else experience this issue and/or have any troubleshooting suggestions?
Old 07-10-2025, 09:48 AM
Here's a copy of the electrical schematic that the service advisor at my local dealer provided.
Old 07-14-2025, 09:17 AM
I got the mower working again! But I wasn't able to figure out exactly what was the issue, so I hope it last.
Long story short, I think it was an issue with the wiring harness. Most likely a pin in one of the connectors not making good contact.
In case this helps anyone in the future, here's what I did to get the machine cutting grass again.
To recap, the push button start (PBS) module's display wouldn't display anything. When pressing the key, the engine wouldn't crank over and only a faint pulsing clicking sound could be heard from the PBS module. Maybe from the relays on its PCB?
To troubleshoot, I first tested the battery and that was good. Then the 20A main fuse which was also okay. I then back probed the two power feed wires on the PBS module and they showed the same voltage as the battery, so it was confirmed that the module was receiving power.
I then tested the voltage on the PBS module wires which should be receiving power once the key is pressed. This showed the voltage dropping from 12ish volts to as low as 6ish volts when the start button was pressed. I'm not sure if this is normal but I suspect that it is not.
Assuming a short or a frayed or partial broken wire, I started looking for one. I ended up testing nearly every wiring circuit for continuity and resistance along with every switch, but I couldn't find an issue. Just to be 100% sure there wasn't a frayed or partially broken wire on the power feed to the PBS module, I tested each power feed wire and these circuits' ground wires with a 12 volt incandescent light bulb. Each wire was able to able to light up the bulb nice and bright so they were all in good condition. I also visually inspected every wiring connector but didn't find an issue.
Not finding an issue and not knowing what else to do, I put all of the wiring back together and tried starting the mower. Without any hesitation, the engine fired right up! I was shocked but relieved. I then reassembled the mower fully and tried re-starting the engine. Again, it started right up without issue so I must have fixed something.
Since it's been working again, I've put another 3 hours on the mower and it's worked like a champ. All I can think of is that a pin in one of the connectors wasn't making a good contact. I'm leaning towards the output wire of the 20A main fuse, but who knows for sure? Either way, it's cutting grass again!
Old 09-11-2025, 02:38 PM
Another update...
After around 10 run hours the mower started having issues starting. It would always crank over, but not always fire up. After around 20 hours of run time since the total no start condition, the mower was really acting up. It was getting very difficult to start and if it did start, it would often stall randomly with no warning.
Troubleshooting the electrical system again, I eventually discovered that when the engine would crank over but not start, voltage wasn't being sent to the EFI's cpu attached to the throttle body on the engine.
Further testing showed that the EFI relay, tapped to the wiring harness underneath the PBS module, was faulty. Sometimes it would work and switch power, sometimes not. When it did switch power, the voltage drop through the switching pins (pins 3 & 5 on the wiring diagram or 30 & 87) was up to 0.43VDC but would reduce as the relay would heat up when power was flowing through it. I switched out the relay with a new one and now the mower starts great and hasn't randomly stalled once!
The replacement relay I used was a genuine MTD unit, part # 925-1648A. The replacement part is not a like for like part. It's from a different manufacturer, it's a different colour and a little smaller. However the pin layout is exactly the same. The service advisor at Cub Cadet told me that they've just starting receiving these different relays and so far he wasn't aware of one failing. He also said that the shop has seen many of these original relay's fail. Seems to make sense on why a new relay is being sold.
I really hope that this is the end of this mower's electrical issues. Some of the issues were just wear & tear from normal use like dirty contacts, some from someone else's shoddy electrical troubleshooting and others from poor quality components selected by the manufacturer.
Besides these electrical issues, the mower has worked great and cuts grass well. It's just a shame that the electrical system is overly complicated with electronics for what a lawnmower requires and isn't more robust. Nobody likes a piece of unreliable equipment, especially for how much these things now cost. Its really a disservice to an otherwise good machine.
Hopefully my electrical issues can help someone else facing the same thing.
Old 09-12-2025, 11:18 AM
CubDieselFan's Avatar
Thank you for sharing your experience. Most of us will never see or work on these newer machines.
You might post some pictures of the mower under the hood.
Old 09-17-2025, 02:06 PM
Here's a few pictures from my troubleshooting.
Tags
hard start, headlight, rzt-sx, stalls
