Old 11-11-2025, 01:35 PM
CubCadet107-129 CubCadet107-129 is offline
Default Cleaning Cub Cadets
This weekend I'm taking my 107 and 1250 to a tractor show, and I need to clean them up a bit. They have original paint as well. Is using a pressure washer and rags the best way to go at it for cleaning? And I was going to use some degreaser as well for the grimy spots. Are there any other methods I should use to get them show ready? Thanks!
Old 11-11-2025, 01:45 PM
Tire black on the tires is a nice touch
Old 11-11-2025, 05:19 PM
Keep the pressure washer directed away from anything that turns, its too easy
to inject water past seals or other components.
Now if dissembling for painting/repair then that is a different situation.
I think you see where I'm going with this caution.
Over the years I've seen way to many needless problems caused by well intended/meaning ppl.
Old 11-11-2025, 05:33 PM
Ozcub's Avatar
Ozcub Ozcub is offline
I would say no to a pressure washer just a nice soft sponge and some high quality Automotive detergent and microfibre cloths for drying
It is old paint and needs to be treated accordingly
Oz
Old 11-12-2025, 07:19 AM
ironman's Avatar
ironman ironman is offline
Don't forget a coat of hand rubbed carnauba wax. We don't want some old tractor to look like some old tractor.
Old 11-12-2025, 06:09 PM
Ozcub's Avatar
What he said
Old 11-13-2025, 08:34 AM
And don't leave the keys in it at a show.
Old 11-13-2025, 09:27 AM
Thank you everyone for your responses and advice! I appreciate it!
Old 11-13-2025, 09:45 AM
garydee's Avatar
garydee garydee is offline
Try one of the "All Wheel and Tire Cleaners" by Armor All or similar companies. It cleans and degreases without the need for a power washer. Simply spray it on and let it do its job for 10 minutes or so, then use a soft brush (an old paint brush works well) to go over everything...
Hose everything off and dry with compressed air from top to bottom. It gets the grime off in areas that can't be reached with the brush as well. I have been using it on all types of things over the years and it's easy on your hands...no need to wear gloves. It's the best cleaner for most everything that needs cleaning!
I like cleaning the paint on my mower deck and other implements with this at the end of the season. The grime falls off and it doesn't mess up the paint like oven cleaner or other harsh chemicals.
Oh, yeah...its also good for cleaning the wheels and tires on your car!!
