Old 09-26-2010, 01:11 PM
gearhead351w gearhead351w is offline
Default New to CC and have questions
Hello guys and thanks for the site great info. I moved and needed a lawn tractor and I was blessed to get a Cub model 1000 built in 75 with a 44 A mower deck. I down loaded the manual for it but I need help. I tried to adjust the deck but the roller on the front keeps digging into the ground even tho I set the ecentric on the side to keep the deck at the highest level?? What am I doing wrong.
Old 09-29-2010, 11:06 PM
Default whish some one would answer my post
I think the title says it all
Old 09-30-2010, 01:17 AM
nicks87z24's Avatar
nicks87z24 nicks87z24 is offline
you will need to adjust these.
Old 09-30-2010, 09:42 PM
NealC NealC is offline
gearhead351w,
If I'm reading this correctly, are you saying that even when you have the deck raised, the front hits the ground? If that is the case, check the hanger frame. It works with a scissors action. If the fork at the rear of the frame was not placed properly over the solid rod under the tractor, it would cause the front to hang down. Also, the frame itself could be bent, or really worn at the attachment points.
Old 10-01-2010, 11:42 PM
I will take a closer look at the frame of the mower deck attachment. the roller that I am speaking of is the anti scalp roller right in the middle of the deck and its scalping the ground on the highest cutting setting.
Old 10-01-2010, 11:56 PM
nicks87z24's Avatar
bent blades?
even flat on the ground it should cut very short but not scalp the ground.
