Old 01-15-2011, 04:51 PM
Frank1541 Frank1541 is offline
Default Will later Cyclops plastic fit the 1541
Hopefully someone has had the same problem. The Plastic hood and side panels are finally to far gone to save on my 1541. Do the plastic parts from say an 1864 fit the 1541. I have never been able to get a dealer to tell me for sure one way or the other.
Thanks
Old 01-15-2011, 05:15 PM
They're the same. They changed the vent style at some point, but otherwise they're identical.
Old 02-19-2011, 11:18 AM
Just and update. The newer style plastic parts fit perfectly and look great. Dang expensive. Matt, thanks as usual for sharing your knowledge.
Old 02-19-2011, 11:57 AM
Dave01's Avatar
Dave01 Dave01 is offline
Are they new, or good used?
My 1864 ones are decent, a few pins broken but stay in place fine. The 2084 needs some work or replacement.
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
Old 02-19-2011, 12:12 PM
cubs-n-bxrs's Avatar
My Cyclops plastic has about met it's match. I have fiber glassed and pinned and patched until there is no more room for any work. Spring time I will be retro fitting my 1641 with all the fixins off of an 82 series machine. Have all the parts to do the conversion just need warm weather. It is pretty much a winter only use machine anyways.
Old 02-20-2011, 11:14 AM
Dave,
I ended up buying new, over $700. The used ones cost up to 80% of new. My hood just fell apart this winter. The mounting areas on the nose broke off. My old side panels are actually in decent shape, but I was afraid that they were getting brittle as well. I plan on keeping this thing for at least 10 more years. I thought about the 82 series fix, but I really like the way the cyclops tractor looks. I did realize this week that these things can become an obsession. I actually spent some time thinking about putting HID lights on it.
