Old 03-18-2011, 11:07 AM
cub_fan cub_fan is offline
Default 1641 voltage regulator problem
I just acquired a 1641 from my neighbor. He was upfront that there was a problem with the electric PTO. In troubleshooting that, I noticed that the voltage on the battery terminals went as high as 15.5 volts when I was near
maximum throttle. I backed off from that in a hurry. It starts fine and the battery voltage is 12.6 volts with engine off. At low throttle the battery reads
around 13v but the voltage increases with engine speed. So I'm assuming that
the voltage regulator is not working. My question is - does anyone know where
the regulator is - I can't find it anywhere.
Also, does anyone know where I can get a service manual. I've seen one
on Ebay which is on a CD and the seller is in France - does anyone know if that
is a good manual?
I assume I should fix the regulator problem before dealing with the PTO.
