Are the engines from the 1882 and the 2082 interchangeable? Specifically the 20hp into the 1882 tractor.
I'm asking as my 1882 has developed a serious oil leak. Not burning - just leaking. I haven't been able to determine yet, where the leak is coming from. Just happened to notice it on the driveway under the front - approximately between the tires. As time permits I will start removing guards and panels to get an approximation of where the problem is. Thanks |
Yeah it's the same motor so swap is a breeze. You're not looking at the one offered in MI are you? Way too much money for a used motor. Seals are cheap and easy. I need a 18M for a build I'm working one so send yours my way.
Oil travels BTW and where it drips from is not necissarily where it leaks from. Scott |
Thanks Scott for the answers and input.
yeah take your time pin pointing that leak as it could be a very simple fix. I'm with murphy, if it's a good running engine, i'd just repair that one even if its a seal
My PTO side seal on my Onan went last Friday, I was on an incline grading a driveway and the oil flowed back into the flyweel fan and blew everywhere including the air cleaner and began to smoke. Thought I blew the motor. I ordered the bearing plate gasket and new seal yesterday and they cost me $33 shipped, Onan parts are 2-3 times the cost of Kohler. I'd like to have that 20 Magnum myself but not at $400+ and not at a 3rd party word that's it's a good motor.
Scott |
At least a couple of bidders thought the eBay engine was a deal at over $600.00
Yeah, there is a limited supply of product out there and guys are humgry for it.
Scott |
