Old 05-12-2011, 10:23 AM
nra1ifer's Avatar
nra1ifer nra1ifer is offline
Default Model 1 Tiller.... will be working on it
I hope to get outside today to look at my Model 1 Tiller. The tines won't turn, but everything else is turning. Something inside the chain drive housing must have failed. I went to Cub's site and printed out a parts diagram and list.
Does anyone have any experience in this area? Any pointers and/or gotcha's?
nra1ifer
Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631
Old 05-12-2011, 12:47 PM
Sugarmaker's Avatar
I will be watching as the #1 tiller I have needs a lot of TLC.
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 05-12-2011, 01:37 PM
ajgross ajgross is offline
Inactive Member
I don't really have any experience working n these yet, but I will soon. I have a #1 tiller and a 1A tiller. The 1A is in pieces and getting ready to be reassembled. The biggest problem I see with them, is the fact that the main gasket is NLA. Both of us will have to cut a new one. My biggest question is do you put any kind of lube inside the chain drive or do you basically just lube the chains real good.
AJ
Old 05-13-2011, 07:39 AM
engel177 engel177 is offline
I friend of mine had the exact same thing happen. A key sheared inside on the lower sprocket. We tried to disassemble the thing ourselves, but ended up taking it to a machine shop to have the big drive pulley pressed off. A word of advice- when you put it back together, use plenty of Never-Seez on the pulley shaft! Also, I almost positive my friend added filler and drain plugs on the chain housing, so the lube can be changed without taking the thing apart.
Old 05-13-2011, 09:42 AM
nra1ifer's Avatar
Thanks for the advice. Didn't get to it yesterday, hopefully today.
nra1ifer
Old 05-14-2011, 07:17 AM
nra1ifer's Avatar
Got it taken apart yesterday. Not a fun job. But, it's amazing how heavily-built this tiller is. I found that a couple of shear pins on one of the sprockets had sheared, probably when I hit a rock. It will be awhile before I get this thing put back together. I'll take the time to clean it all up and replace several bearings while I have it apart. Luckily, I have an old Troy-Bilt Horse to use. That's what I used exclusively before I found this 123 with the tiller attached.
nra1ifer
