Old 12-27-2011, 04:19 PM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Default Suit case weight bracket
I have a couple of extra mule drives for my 2284 that are bent and I was thinking about making a suitcase weight bracket for the front of my tractor. I would only use it when the deck is off for plowing/grading and such. Anybody done this kind of set up or suggestions on whether it will work.
Don Smith
Old 12-27-2011, 09:03 PM
cubguy's Avatar
cubguy cubguy is offline
looking forward to this thread. I could really use a weight bracket too.
Nroakes
Old 12-27-2011, 09:59 PM
Google "cub cadet weight bracket" and see what you come with. There are lots of pics from here and other forums. You could search for wide frame too.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 12-27-2011, 11:12 PM
I'm going to enjoy this thread, as well.
Old 12-27-2011, 11:23 PM
dieseldan123's Avatar
Ive made two weight brackets for my tractors. Built on for the 1811 i used to have and one for my 1450 resto-mod. The bracket i made for the 1811 could be used along with the mule drive, doubled as a bumper, and bolted into the stock holes in the frame.
The bracket i made for the 1450 was made out of spare steel i had laying around and a home made lower 3pt hitch bracket that didnt work with my equipment. It bolts on using the lower grille bolt locations with a support brace that hooks under the frame and can be used also with the mule drive attached, more pics and info can be found about this bracket in the IH section with my thread IH 1450 resto. Hope this helps! As far as it helping i have close to 55lbs on the front including my 3lbs apiece weights and the bracket itself. When i take the weights off i notice the front tires lose their "buldge" and the tractor feels solid going up hills and ditches.
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 12-27-2011, 11:45 PM
I added 8 extra holes in case I ever wanted to add some future use attachment.
The 1/2" thick bracket alone adds enough weight for most uses.
It also makes a great bumper!!
