Old 08-20-2012, 12:54 PM
fleetlines's Avatar
fleetlines fleetlines is offline
Default Repairing my parts 1650
I got a 1650 for parts for my first 1650. It had the three point hitch, tiller, and gear box as well as a few other parts I needed. Over time I striped her more. I got a cab for throwing snow this winter recently then found a mutt of a cub with a 14 hp engine and cab. Most of the parts needed to repair the 1650 parts machine were there so I set about with the plate glass, sandpaper and head, decarboning, starter, carb rebuild, points and she was running for the first time since I had it. Swapped out some tires, replaced the PTO, changed the PTO switch, changed fluid in the rear, ran the wires - replacing some, replaced battery and swapped out seats. Lots and lots of little things had to be worked out as well.
The engine shakes a little bit so I got new/old stock ISO mounts. The plate for the safety switch (clutch) is gone so I've bypassed it till I can get or make a plate. I also need the alum. backing plate for the muffler. Thinking I might want to do stacks instead because I've had so many of them that were broke.
She's running alright now (still without the exhaust). I'm thinking the other cab should go on her but remove the glass and doors and use it as a sun shade.
Current ISO mounts:
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 08-20-2012, 01:05 PM
Looking forward to your updates, Curtis!
