Old 09-17-2012, 03:33 PM
Default 1864 implement lift
The mower deck cylinder will not go up/down, even with no deck on the tractor. There seems to be very little pressure in the lines at the control valve.
The PS works good without a lot of noise but it does make a little more noise in one direction than in the other. The transmission seems to pull okay except it does slow down (maybe too much) some when pulling a grade.
Someone on another forum suggested there are check valves in the steering box that may/may not control the pressure going to the implement lift. Needless to say, I'm a little reluctant to start taking that thing apart looking for something I know nothing about unless that's where the problem likely is.
Any advice?
Old 09-17-2012, 07:39 PM
This must be an uncommon failure in an 1864. Dealer service department had no idea either.
Old 09-17-2012, 08:28 PM
Mike
This is from the tech section
http://www.onlycubcadets.net/forum/s...ad.php?t=13226
Click on the link, down load it and save it. Read it. It should give you some ideas to check.
Old 09-18-2012, 05:03 AM
Thanks, is there a hydraulic flow schematic somewhere?
I've seen the diagram but no flow.
Old 11-05-2012, 03:09 PM
I just discovered today that I can saw the steering while back and forth and while the wheels are moving, I have enough pressure to the control valve that the deck will go up and down.
Anybody want to take a guess?
