Old 02-08-2013, 07:11 PM
Tim.E's Avatar
Tim.E Tim.E is offline
Default Is there any hope for a Walbro carburetor?
I bought a spare engine that came off a 149. It had not been run in a while.It Had a Walbro 60 carburetor.Of course it did not run right.It would only run with the choke nearly closed,like it was starving for fuel.I disassembled it and soaked it in carb cleaner,but it did not help.So,I gave up on the Walbro.I got a Carter Kohler #30 carb from Ray (Thanks,Ray) and the engine runs and starts great now. I was just thinking,if I could somehow get that Walro carb to work,then I would have a spare.Has anyone had any luck bringing a Walbro back to life? Or am I just dreaming?
Thanks.Tim
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 02-08-2013, 08:33 PM
Walbro's are excellent paper weights.
Old 02-08-2013, 10:54 PM
thomas 1863's Avatar
thomas 1863 thomas 1863 is offline
Make sure the main fuel inlet needle that goes from the fuel bowl to the middle of the carb is clear. A small pin for fabric works well for clearing them
Old 02-09-2013, 01:54 PM
Tim.E's Avatar
Thomas, I don't understand what you mean. When I look into the center of the part that protrudes down into the bowl, I see the end of the needle sticking out. Since this is a Walbro, I don't know if it is possible to remove that needle/jet.
Old 02-09-2013, 02:36 PM
IIRC, all the Kohlers for Cub Cadet, in that series, had the adjustable Kohler (Carter) Carbs on them,
Old 02-09-2013, 03:21 PM
I have two newer Kohler K series replacement engines in a 129 and 126 and they both have Walbro carburetors on them. I havent had too much problem with them yet....keep in mind i said YET....
Old 02-09-2013, 03:22 PM
never had a walbro carb on anything, but from what I've heard, it's best to avoid them like the plague.
