This may be an old question,so if I apologize in advance. What octane of gas does everyone here use? I'm switching to the high octane alcohol free. Have rebuilt two carbs and my k301 in my 1200 is still hard to start! Its getting enough gas,has good spark has compression and is timed right. I think its the crappy gas. I put new needle and seat,gaskets and the throttle bushing in cleaned the carb inside and out and blew out the needles and all the passages.I 'm gonna try new gas,or some octane booster first and see what happens. The fuel tank is clean as a whistle too,so anyone have some input?? Thanks,Brian
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
87. Always. Blended is my only choice. (We have a refinery and an ethanol plant in my county.) I've rebuilt alot of motors, carbs and the like.... sometimes you end up with a "cold natured" motor. I can offer ten different things that can cause a hard start... but I have found sometimes that's just some engines nature. As long as it will start, and it runs fine... you just have to deal with it. Try the higher octane fuel, it may help. Sounds like you've checked everything I would have suggested!
I think you are wasting your money! I use 87 octane E 10.
The main thing with E 10 is to use storage cans that are sealed to keep water out. Don't leave your tractor sit out in the rain. |
I run Sonoco 93 no ethanol only because I can't get 87 no ethanol here. I'd prefer 87 if I could get it. Alcohol belongs in booze not gas.
87 octane laced with Startron. Great stuff.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Same, same!
87% plus Startron----------------- engine runs happy, happy. ![]() Enzyme to kill ethanol, plus proven to reduce carbon build-up. Nik
It dont cut grass, but its yellow. |
Just got my ltx1050 using shell 93. Probably extravagant but I do not plan on having another mower as I'm 63 now and want to give the machine every possible advantage.
I run 91/93, whatever the top fuel is at the pumps with Startron and MMO. The cheap plastic cans that don't seal very good, some not at all, are kept in an unconditioned shed on top of a wooden pallet. I have never had any fuel related issues.
Thread Tools | |
Display Modes | |
