Its about the same size as the dump cart they sell for $100 at just about every place. I needed a small cart that fit through my gate to a small fenced area of my yard.
I picked it up for free from work and after I get the 2 new tire assemblies it needs I'll be in it for about $20. ![]() Measures out to 11. 7 cubic feet and has a stated weight capacity of 700 lbs. If I can find the scrap steel needed I might turn it into a 2 wheeler but for now it's just what I need. I plan to throw some logs in it once I get the new tires and see what if anything needs beefing up. I'm sure a few gussets here and there will greatly improve the strength. Balance shouldn't be bad it only extends 4-1/2" over each side of the cart I also need to Weld up the side panel I cut down to fit as a tailgate and figure out the mounting for that so it swings downward in the back.
Cub 104 Refurbed Sprinig of 2013 Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs |
You could make a heavy duty piano hinge out of 4 heavy duty door hinges by taking the pins out and using a long steel rod to connect them. This way the back panel could easily be taken off by pulling the rod out for hauling long logs or whatever.
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
You could attach the panel at the top with heavy duty lock hinges using spring wire pins .
Nice cart!
Neat cart, you have there.
Nice but I like My no2s hehe
| Thread Tools | |
| Display Modes | |
