Hey guys on my blower if you look in this pic the sprocket that is on the end connected to the shaft is moving towards the left almost hitting the adjustment bolt how do I get that centered?
You mean the sprocket is moving on the shaft?
![]() How about a little closer pic...... |
I don't think so I grabbed it this morning and it seems to be tight it does not move when running that I can see I took a pic but my dayum computer won't recognize the pic I will try to get it upload today here is the pic
Get it dried off and cleaned up and then post some good pictures we don't have to use X-Ray vision to look at. I'll bet you will find something broken, bent or missing.
Ok here are some more it looks like the PO may have notched the blower housing alittle because of it
This time of year it's not of fun job, I did a replacement gear on mine last season, had the same issue and found a spacer/washer had been missing allowing the assembly to shift over. I suggest pulling it apart and make sure all the drift pins are intact and all your spacers are in place, you can't tell anything from your pics.
| Thread Tools | |
| Display Modes | |
