When first trying to start the cub after it sat for about a week I cranked and cranked and cranked... occasionally it would try to start and then kick the starter out with out starting. I checked the fuel filter it was full of fuel I lightly pressurized the tank to get fuel to the carb still no start. As a last resort I gave it a shot of ether still didn't start until I gave it a few more shots then it finally hit but acted as though it was really starved for gas (barely running) but finally took off and ran good. I let it run for a few minutes turned it off and checked the spark plugs one was gapped at .035 the other at .025 I gapped them both at .025 like kohler specs said. They were a little carboned up but over all looked to be in good shape with no signs of oil fouling, to lean etc.The electrode was like new. I then grounded them to the block and turned the engine over they have a nice blue spark. You would think if it were a fuel problem then it would have started when I first sprayed it with ether and if it were a spark problem then I wouldn't have the good blue spark. When its running it purrs like a kitten and when I give it the throttle it roars like a lion. What am I missing, what are some of the issues that the magnums had as far a starting problems.
looks like your cub caught the 1872 flu that's been going around. i think your the 4th member i've seen in the past 2 weeks with the same issue.
i hope mine doesn't catch it.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
It wasn't to long ago I was telling that to A Cecil. I think there is something going around it must be getting spread through this forum LOL. Good luck with yours.
Something definitely going around with the 1872's. My buddy checked today and my 1872 hardly had any spark. Going to have the ignition module replaced.
Did that cause it to be a yellowish spark or was still a good blue spark?
My experience similar to yours turned out to be crud in the tank, line and carb. Not enough to keep from running but enough to make it real hard to start and make it run hot due to being lean. Buy a new plug but check the fuel and carb too. Get a good clear glass jar and let all of the gas drain into it and let it sit for a day to see if you have any sediment in it. Do it before the filter just to be sure that it is there or not. Then if it is, clean and flush the tank, get a new fuel line/filter and clean the carb and all of it's orifices.
Good luck ![]()
1811 Hydro "Failing to prepare is preparing to fail". ![]() |
Thread Tools | |
Display Modes | |
