Old 01-11-2014, 08:00 PM
1811woody's Avatar
Default What is this bracket 1872?
Not sure what this bracket is for its galvanized, its about 6" long it came with the 1872 in a unmarked box. Something for the plow? Or a flux capacitater
Old 01-11-2014, 08:04 PM
CTRUEX CTRUEX is offline
Looks like the rockshaft support brace, part# HA-14297. It is NLA. Feel free to send it to me, or install it on your 1872, along with the front blade.
Old 01-11-2014, 08:28 PM
1811woody's Avatar
where did you get that number from perhaps i'll change my mind
I found it your right it does look like that part but I havnt quit figured how it goes on yet
Old 01-11-2014, 10:19 PM
ccpullin ccpullin is offline
It's for locking the rock shaft so you can power down the blade so it does not float like a mower deck needs to.
Old 01-11-2014, 10:53 PM
1811woody's Avatar
Ok that makes sense how does it bolt up?
Old 01-11-2014, 11:03 PM
No... it's not for power down, it's for added lifting strength. It ties the inner and outer rockshaft together. You have to install a "float lockout" pin to make it power down.
Woody, check out this thread. It has pics.
http://www.onlycubcadets.net/forum/s...ad.php?t=29304
Old 01-11-2014, 11:13 PM
1811woody's Avatar
I see now. A picture speaks a thousand words. It makes for a really short thread though LOL Thanks!
UPDATE I made it out to the garage to check the rock shaft brace and discovered it may be to late to put it on. The previous owner ran without it as did I not knowing what it was. The deck lift tabs on the rock shaft appear to be slightly tweaked from side to side and the hole in the brace doesn't line up with the hole in the bracket that's on the outside of the frame. The bracket is about a half a whole out of alignment. Im not sure this causes any major issues other then I cant use this bracket and will,
A- either have to repin the rock shaft
OR
B- have to make a new bracket with the hole adjusted to the new position.
Some where along the line someone has welded a piece of angle to the rock shaft ears (from on side to the other)I suppose to address a sheered pin issue?
Old 01-13-2014, 08:53 AM
squatch squatch is offline
Rockshaft brace. Never mount a blade or front equipment without it!
On my 1872.
This is what it prevents.
http://www.onlycubcadets.net/forum/s...ead.php?t=2912
Old 01-13-2014, 08:56 AM
Nope that is done by adding a bolt to the rock shaft arm inside the frame rails.
This bracket just connects the weak front lift arm to the much stronger deck lift arm for those heavy blowers and blades a super can handle.
Old 01-13-2014, 12:43 PM
1811woody's Avatar
Wow that's gotta suck(can I say) check out this thread thhttp://www.onlycubcadets.net/forum/showthread.php?t=29410at) I'm clearly seeing why the PO upgraded my plow frame and the more I see why the better I like it.
