I recently rebuilt the engine in my 125 (its actually got a 14HP engine). I put my snow blade on that and realized that its kind of hard to lift. Does anyone have a picture of where the lift assist spring hooks up on the front, and the diameter and length of the spring itself, and I will make a lift for mine. Thanks
It d osnt hook up on the front at all actually. It attaches to the rickshaw then runs through the frame to the back where it attaches to the seat base . Ill look to see if I have a picture showing the rear
No more cubs. But never fear there will be more ![]() ![]() ![]()
This isn't the best pic but you can see the bolt to the left of the 3 point that is the ih spring assist which works way better then the Brinkley which is on the right and requires a 3 point to use. Im sure someone will chime in with better pictures
![]() Here's the spring assists that are used on a narrow frame cub cadet ( your 125 is a NF ) The Brinly will not work well on a hydro drive cub due to the spring hitting the hydro pump. ( I tried ) The forward spring attachment connects to the rockshaft, the precision bent 1/2" rod clear items underneath and the spring attaches to an angle bracket on the back on the frame. It does make a good difference and is well the money.
I agree about making the blade lift easier. I have a I.h. One and I love it.
Yep I forgot to mention the Brinkley one wont work with hydro. Its about useless by itself anyway. But the ih spring cranked about half way down is enough to hold my front blade anywhere I put it
I had both the IH and Brinly on my 122. Made it much easier to use the QA42 and the rototiller.
| Thread Tools | |
| Display Modes | |
