Old 01-20-2014, 06:02 PM
steven8979 steven8979 is offline
Default Will a 14HP fit in a 1250?
Kind of a dumb question but I'm here at my shop working on the 1250 I think the 12 hp kohler I had in it jumped timing so I swapped it out with the 14 hp from a 1450 I had a while back. so my question is, will a 14hp engine fit in a 1250 with the same mounting brackets or do I have to swap the 1250's brackets with the 1450s? I'm at my shop as of right now working on it if any cub guys are within Jamestown, Busti NY area comon' down to the shop! any help is much appreciated ! I'd post some pictures but the shop computer is JUNK!
-Steve
Old 01-20-2014, 06:32 PM
Steve,
Yes, it sure will.
Old 01-20-2014, 06:40 PM
IH Cub Cadet IH Cub Cadet is offline
I am 99.9% positive it will fit.
My 1650 as it turned out came with a 14 hp engine under the hood vs a 16 hp engine and it bolted right up. I've got a spare 16 and 12 hp block for these QL tractors and the oil pan is the same as far as I can tell between the 12, 14 and 16 hp engines, so I think you would be fine - same mounting, brackets, etc. One thing you might try if it's not to late is the cradle mod. I did that with my tractor and is a definite improvement.
Good luck,
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 01-20-2014, 07:24 PM
Thanks guys! The only issue im having now is getting the engine bolt holes to line up! grrr..
Old 01-20-2014, 07:31 PM
Close one eye....
Old 01-20-2014, 08:18 PM
I normally use a #2 Phillips screwdriver to line up one of the rear holes, then thread the bolt in part-way, do the same to the other side and then the front two are almost always good.
Old 01-20-2014, 06:33 PM
It will fit. Mounting plates are the same.
