I made this puller today from some other designs I've seen here. I started with the round tubing that measures 1 5/8 inside diameter. This fits over the pulley hub. I drilled two 5/16 holes directly across from each other 1/2" from the end of the pipe. One of these holes gets a 5/16 nut welded to the outside of the hole. Its easiest to put the nut on a bolt and the bolt in the hole to line them up while you weld. The other hole stays with no nut. I then got a big washer to cover the other end and welded a 3/8 nut in the center of that. The big washer was then welded to the pipe from the inside. The puller is now attched to the hub with a short 5/16 bolt through the plain hole and into the deeper empty set screw hole. Tighten the bolt until it bottoms out and then back out 1/8 turn. Insert another short 5/16 bolt into the welded on 5/16 nut and tighten down firmly. Now insert a long piece of threaded 3/8 rod with 2 nuts locked together on the end into the end of the puller and tighten until the hub is off the shaft. I sharpened the end of the 3/8 rod some to help it align itself in the end of the crankshaft. I also soaked the hub with pb blaster the day before and didn't use any heat on it. No damage to hub or shaft and no extra holes in the pulley.
Collection: 100, 71, 128, 169, 582, 682, (2) 782. 1980 Scout Traveler Diesel. |
Nice job on the puller!
I need to dig the one I have out. They are for the residential HVAC service people to remove blower wheels and condenser fan blades. Same type of design....maybe I can find where I put it.
Thread Tools | |
Display Modes | |
