Instead of hijacking other threads here is mine. Thanks to Steved and Sam mac for their threads and insight on the PTO. Just got the thing off. WD-40 actually worked for me. There were 3 short and 3 long, 1/8 allen head set screws. Once I got them loose I just bumped it with a rubber mallet and it came right off
Lots of rust on the pressure plate and friction disc. I'm wondering if I can knock that off with a grinder on the pressure plate(got a new stripping disc) or if I need to get a new one? The snap ring looks to be toast, and the clutch bearing feels like it's got rocks for bearings! Here's some pics:
Good work. You can strip the rust off of the plates and sand them down.
I wasn't sure if it needed to be turned on a lathe or not. Didn't think it would hurt it though. Need a new clutch bearing and snap ring. About to go back out and see what kind of damage I can do to the rust.
Turning the plate in a lathe would be the best way to do it.
Think I need something stronger than WD-40 for the clutch bearing locking collar, started to bend my allen wrench
![]() Hit all of it with a sanding disc. There is a lot of pitting on the pressure plate, and I have no way to grind it "true" without a lathe.
Looks like you need a new plate, I wondered if you can flip them over and true up that side?
| Thread Tools | |
| Display Modes | |
