Old 05-28-2014, 11:26 AM
bentlyf1 bentlyf1 is offline
Default New member From WI
just found this site I have a 1641 that I bought last winter runs good except for a small electrical problem of not wanting to charge when the mower is engaged.
Old 05-28-2014, 01:46 PM
Sam Mac Sam Mac is online now
First welcome to OCC.
Next are you seeing the flickering charge indicator light while mowing? That seems to be a very common issue with the Vanguards. Make sure your running wide open when you mow, they don't make full voltage till max RPM, make sure the battery is in good condition and if you have a volt meter hook it up to the battery while your mowing to see what is actually happening. That charge light is not a reliable indicator, in fact the last Cub I worked on a LT2180 didn't even have one so my guess is Cub has done away with that setup probably because of complaints. If it starts reliably it is probably charging just fine. One other issue is Vanguard voltage regulators/ rectifiers are not the best. I've changed 3 of them this season. I converted one to a Kohler and it works much better along with being much less expensive.
Post questions about your 1641 in this section. CCC/MTD Cub Cadet built Tractors (GT)
Old 05-28-2014, 02:07 PM
Welcome to OCC!
Welcome to OCC! Glad to have you!
Old 05-31-2014, 10:06 PM
cubby cubby is offline
welcome to the site . where abouts in wi you from, im near green bay
just wondering
