Old 08-07-2014, 07:14 PM
raffterman raffterman is offline
Default 1620 seat switch has been by-passed
My father-in-law has a 1620 and the seat switch has been by-passed and he is afraid if he has a heart problem and falls off the tractor it will just keep going which is true . Can any of you folks help me figure out how to connect the seat switch back up . thanks for your help.
Old 08-08-2014, 07:57 AM
rdehli rdehli is offline
need a little more info. Is there just a jumper wire or has the harness been modified, got a picture? thanks
Old 08-08-2014, 08:13 AM
The Seat Switch is a SPST switch that is normally closed. It has two black wires going to it. Simply remove the jumper wire and install on the switch. It does not matter which terminals that the two black wires go to.
The theory of that circuit is. IF the PTO is engaged and running and one gets off the seat, it will kill the engine.
BTW.... If these two black wires are jumpered together, how does this engine run...?? There must be some other electrical modifications that have been made.
Welcome to OCC.
Old 08-08-2014, 09:38 PM
Don't see a jumper , the switch is unplugged and when it's plugged in there is no effect, the tractor runs great and the PTO is not affected. I see there is a seat relay somewhere and I can see a relay on the back of the battery tray, but don't know if it is seat relay.
Old 08-08-2014, 10:18 PM
When you tried plugging it in, did you get off the seat with the PTO on?
