Old 09-04-2015, 03:03 PM
jmack jmack is offline
Default Troubleshooting 1811 charging issue
My 1811 isn't charging the battery properly.
The biggest problem I have right now is identifying the exact location of the:
1) rectifier
2) voltage regulator
At full throttle the battery is showing approx ~12V, but as the engine warms up this appears to go down. If I turn on the lights, the voltage drops to ~5v so something is definitely not working.
The service manuals that I looked at weren't very specific in this regard. Images on Google for a Magnum 18 rectifier show a thin metal plate with three leads, but I can't see that on my machine unless it's buried under the shrouds somewhere.
On the left side of the chassis there is a metal box with a 3 prong connector attached to it, but I am not sure if that is the rectifier?
Looking for any one who has gone down this road before for some insight.
Thanks,
John
____
782 running and cutting, soon to be blowing
71,109,122,127,1572 in various states of dis-repair
Old 09-04-2015, 03:10 PM
j4c11's Avatar
j4c11 j4c11 is offline
1) rectifier
Thanks,
John
It's bolted to the rear shroud and somewhat hidden underneath the intake manifold. You can get to it more easily by taking the intake manifold off.
Old 09-04-2015, 04:05 PM
A picture is worth a thousand words...
Thanks! Going to do this now.
____
Old 09-04-2015, 04:17 PM
you prolly can get to the leads without too much trouble, once you locate them as pictured.
Should have about 28 Volts AC measured between the 2 outside leads.
And center lead to ground about 14.5Volts DC @ full throttle.
Old 09-04-2015, 04:29 PM
j4c11's Avatar
To measure the AC you can just unplug the connector and measure directly on the connector. To measure the DC you will have to plug it back in and measure elsewhere, either at the ignition switch or trace the wire corresponding to the middle lead to the next connector. I don't think you can get directly to leads on the regulator due to connector and lack of space between it and the manifold which runs right over it.
Old 09-04-2015, 06:55 PM
I can't speak for a 1811, because I don't have one readily available, but I do have an M-18 in my 782 and although not wide open, the leads can be accessed just behind the air cleaner ahead of the manifold and it does help if the air cleaner is removed.
but maybe there are obstructions on an 1811 that I'm not aware of.
to remove the regulator/rectifier looks a little more entailed as the retaining screws are directly under the manifold runner.
A box/open end and magnet will be beneficial for sure
Old 09-04-2015, 04:30 PM
That is 14.5 VDC measured from the center terminal to the negative battery terminal.
