Geo Metro motor, Ford frame, cub transaxle. Homemade alum intake,1bbl rochester carb. Has stock cub welded transaxel. It's made 1 trip down the track with big tires(19 2nd gear too slow). Next trip is gonna be small tire in 3rd(26) then it's gonna come out for a fine spline rear and gears i have once i decide what overdrive to put with them.Started with a truck load of parts (junk). PO had stretched frame and had motor installed. They started it up without a driveshaft and destroyed clutch and throwout bearing arm.(either pushed the clutch to far or the main shaft backed out of the pilot bearing). I had to stretch the hood, raise the dash 4", get new hoses and straighten everything out. It does run really well, if it will stay together. Mike
now thats cool, congrats.
Don't know if you'll win any pulls but that is certainly a neatly done machine! I like the Ford tractor theme.
That thing is sweet!! Keep us posted as to how she pulls!
John |
I'm not at all into pulling (not that I think there is anything wrong with it, just not my thing) but I must say that, that is pretty impressive. It looks like a really clean build, you have every reason be very proud. Good luck getting your gears set up.
| Thread Tools | |
| Display Modes | |
