Old 04-29-2017, 10:54 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Default Cat 0 lift mod 1864
Decided to try a lift capacity modification on my OTHER 1864. Wanted to do it as economic as I could while being able to have the 3pt separate from the deck lift. From start to finish it took me about 6 hours. Half of that time was spent swearing and thinking.
I still have some loose ends to tie up and need to weld the float straps on when Jeff gets around to milling them.
Going to try it out on my R-Bucket tomorrow.
1- 1200 in pieces
1- 1864 in pieces
Old 04-29-2017, 10:56 PM
rdehli rdehli is offline
looks cool
Old 04-29-2017, 11:01 PM
Very nice! Looking forward to hearing how it does for you.
Old 04-30-2017, 07:09 PM
Rescue11's Avatar
Thanks guys!!
Well I tested it out today, good results. I think a 3pt is not useful if it does not lift the front end off the ground. This one will do that now! The first test was lifting the front of a 782 with 120 lbs of suitcase weights in the bucket. This lifted the front end off the ground.
The second test was loading the bucket full of rock without struggle. SO, Im satisfied for a secondary tractor 3point.
The lift travel is 12", which is what it was by using the extended holes previously, only the 3pt would not even lift 150 lbs in the bucket. My hydraulic pressure has remained the same ( 800 psi ) as always so this was a very fair test.
1- 1200 in pieces
1- 1864 in pieces
Old 04-30-2017, 08:24 PM
Terry C's Avatar
Terry C Terry C is offline
Great work!! I've got to come down and check that bucket out
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-30-2017, 09:01 PM
Glad you had good results!
Old 04-30-2017, 09:21 PM
Dirty Steve's Avatar
Not too shaby!
