I just picked up most of a 2284 last night. It needs a few parts, and a cleaning. I already know it needs a cork gasket and axle housing seals... and an engine and hood
![]() Everything is wet back around the rear. But the tires are good, steering is good. I paid $300 for it and drove 3 hours both ways, I probably overpaid a bit I think, but I'll have the Super I have always wanted when all is set and done. 20170927_022536623_iOS.jpg I am wondering about the front tire clearance to the axle beam though. Seems awfully close. Is this a bent axle or just an extra fat (over inflated) tire? The other side has about 1/4" to 1/2" clearance and feels inflated the same. I didn't check tire pressure yet. 20170927_022604131_iOS.jpg 20170927_022611264_iOS.jpg I'm going to have to do something to treat my Yellow Fever soon, my almost 13 year old daughter is becoming embarassed by all the parts tractors in our yard and driveway now. ![]()
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
![]() ![]() ![]() I have been known to buy such critters......
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 ![]() ![]() {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
Thanks... skeletonized just means just less I have to take off to clean it up...
Looks like the one I saw on Allentown pa CL.
I remember when it was complete. hehehehe. Are you sure those are super front rims? Nice find, though you paid too much.
That's the one. What do you know about it? I'm not sure if those are the super rims, the seem to be the right width for the axle and everything. The tires are 20x8x8. Looks like they should be 18x8.5-8 according to tractordata.com. I guess that answers my question, I didn't look much up about it, I just saw the 2284 chassis and got excited. It was too far and too much $$, but I already have most of what I will need to put the meat back on the bones, so it won't cost me a lot in the long run. Certainly not $1200+ like these things pop up for sale for complete and probably need torn apart and gone over anyway.
I know I missed out on it when it was for sale for 250.00. heheheh
More than likely those are the wrong tires. Be sure it still has the super tranny or pump in it. I saw one on CL a while ago....
I be checking the wheel bearings. I had one on my 1864 like that, and when I pulled tire and rim the inner wheel bearing fell out in pieces. ![]()
Don B, USAF 1962-1968, Ft. Wayne, IN |
There is a picture of the front end of a super in here
http://www.onlycubcadets.net/forum/s...t=49506&page=4 shows the tire to axle clearance
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580 |
Well I started the tear down today. I am excited and couldn't wait much longer. I've never seen so much filth in the rear area, so I assumed the worst... that there was a leak. After I got the layers of dirt and grease, and greasy dirt out of there, I found the leak. the one axle carrier is shot. Both holes in the top are shattered and one has a broken off bolt flush in the hole, and its missing the tab on the left side. So I need to replace parts. I have all the parts here that I need, the housing and the carrier tubes. But they aren't "Super" ones. So I know I need to swap the reduction gear over from the mangled super rear to the other non super aluminum rear housing I have. Problem is I can't get either one to separate the front part off the main part to get to the reduction gear. Usually I knock stuff around with a rubber mallet and it breaks loose, but neither of these are doing so. What can I do to get them apart?
That is because behind the welch plug there is a ring holding the shaft in that goes to the reduction gear.
You will have to re shim it when you reinstall it..
Thread Tools | |
Display Modes | |
