Old 04-17-2018, 01:01 PM
swacor swacor is offline
Default 1864 and 451 blower
Just wanting to know if any of you use the sgt extensions on the 1864. If i drive mine on a board with the blower all the way down it appears the square tubes actually lift the blower up and the lift links are loose. Any thoughts?
Old 04-17-2018, 01:37 PM
The 1864 is not an SGT, so no, you can't use the SGT links or it won't raise.
The 451 was made for the 1864, so with GT links it will work fine.
Old 04-18-2018, 12:43 AM
Yes i know its not a super. I was talking the extension brackets to lower the tubes to less of an angle, not lift links, mine are adjustable. My tubes were contacting the blower itself causing it to raise. I put the ext brackets on and adjusted everything to the manual and seems to lower good now when front end is off ground 1-1.5in.
Old 04-18-2018, 02:02 AM
Sounds like you have other issues. Shouldn't need the brackets to make it work.
Old 04-18-2018, 06:16 AM
Dirty Steve's Avatar
Agree with Jon. Something is not right. The manual should help.
http://www.onlycubcadets.net/forum/s...ead.php?t=7435
