Hey fellas, I hope all of you in the north east are preparing for this polar vortex coming!
Not sure how concerned I should be here, but today plowing snow with my 1282, I noticed it bogged down twice while pushing minimal amounts of light, fluffy snow. It was a very quick change in rpm, but it immediately picked back up. Maybe particulates in the fuel? Cold temperatures? Other than that it ran like a top. Below are some key points you may ask. 15 degrees F ambient temperature. 3/4 tank full of fuel. Recent Oil Change (5 hours ago) w/ 10W-30. Oil level was good. Air filter clean. Let it warm up for 5 minutes before moving. Anything else I should consider? I just want to be proactive, but I may be worrying for nothing. Thanks guys. ![]()
-Derek Cub Models: Original, 100 (x3), 1282, 1572, XT1 LT46 |
Derek:
X2 on fuel, sometimes in cold weather moisture causes problems not only in the tank or filters, but a small amount in the carb bowl can cause problems.
If you pull the choke and it immediately gets better, you have a fuel issue. |
Thank you for the feedback guys. I'm thinking the same thing. I've never ran this tractor in temperatures this cold. Honestly, I don't plan on running it until the temps come back up above 0 degrees F.
The highs could remain below 0 degrees F for the next couple days. Wind chills around 40 below. ![]()
Had a fellow bring his 1200 into my shop last week, complaining of the same thing.
Turns out he had the main jet turned out 4 and 1/2 turns!! Damned thing was flooding itself to the point it would quit and he was at about his wits end. |
I also have had carbs ice up on the outside, as well in the venturi
especially in moist/cold weather. I have actually watched them turn into an ice ball. just something to check out, usually tho, they run rich when doing that. |
![]() Quote:
It reduces the heat loss from your head and your entire body is warmer then. |
Just walking to the car in these temperatures is brutal enough. I have so much respect to the men and women who work in this type of weather.
Thread Tools | |
Display Modes | |
