Can I put a 2" hitch ball on my 149 to back up my sailboat into the back yard? It's 2000 pounds, single axle trailer. It would be a lot easier to back it into the yard rather than using my truck.
1973 Cub Cadet 149 2023 John Deere X590 Farmall B sitting in relative's barn |
You might as well do it,, everyone else does it,,
![]() Stay away from grades,, the brakes will not stop much,,,
I just don't know if there's enough "meat" in the rear hitch hole for a 2" ball. Hitch weight is 200 pounds, so that should be nothing for the tractor.
It will tow it and back it no problem zimm. No grades here so you’ll be ok, just like everyone says towing and stopping something are 2 different things. The only drawback is the st Augustine grass that’s real soft but you know that already living in Fl. I just moved a double axle oldschool RV with my 102 in a guys yard as it needed to be in a very tight spot that no truck could maneuver, no issues. A lot of my cubs have been modified before I got them to move boats, even one that had a front mount receiver.
Will it move it? Yes it will. ANYTHING resembling a grade or if it's wet and ALL best are off. You will find yourself on "Mr Toad's Wild Ride" as the boat pushes you anywhere it wants. If you luck out, it'll stay straight. If it gets you sideways ....
My pop up is 1500 LBS empty, requires a 2" ball. I can only get a 1 7/8 ball into my 147 drawbar. I give it 1/2-3/4 throttle, take my time and shove it around with that. Yeah it bangs a little bit when I'm going or stopping, but I'm only going 1/2 MPH. Oh and I have some grades on my property too.
Here’s a home made deal that’s on the rear of a 128 in my cub graveyard. Never used it personally. I have used different models of cub cadets to pull things beyond crazy/dumb...... just be careful and take it slow
-Rick IH 782 IH 126 CCC 1863 |
I have hauled my 1320 with my 147 before, and didn’t do any damage. Just stay off hills, and go slow.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
| Thread Tools | |
| Display Modes | |
