I have the brake down, PTO off, in neutral, and turn the key nothing.
There is a Bosch relay hooked up to the starter, and while turning the key I can feel it buzzing. The odd thing is, I started it and pull it out of its parking place, to grease all the tractor and deck fittings. When finished when to start it an nothing. Dash light is showing dis-engage PTO, I have the PTO dis-engaged. As I am not the greatest electrical troubleshooter and help/ideas will greatly be appreciated. Plus both fuses show continuity. Thank you for your time.
Don B, USAF 1962-1968, Ft. Wayne, IN |
Turn the PTO on/off a few times and see if the light goes out. You should be able to hear it engage/disengage with the key on.
How much charge do you have in your battery? Try jumping it. A relay won't close/open if it doesn't have enough power and can vibrate or buzz a bit. Think of a dead battery in your car clicking and not starting. Same thing. Not enough to keep the contacts together with load.
This series of tractors, cyclops, have many interlock switches. Each has a connection may become loose or dirty reducing the voltage. Suggest cleaning each switch to wiring contact plug, key switch, PTO switch, brake switch, neutral switch and seat switches.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580 |
Other than safeties, check your grounds, and check them again. I don't think the relay would do anything if a safety switch was open. If it's making noise it's getting some power from somewhere. Don't give up on it too quick unless you're in a bind.
| Thread Tools | |
| Display Modes | |
