I have a cub cadet 1210. The blade farthest right will not cut grass. The other two do with no problem. I looked underneath and the problem blade is in the shape of an "x", the other two aren't. Is this the problem or is it a belt problem? I'm hesitant to think its a belt problem because the other two blades give me no issue. Any assistance would help. Thanks.
![]() ![]() Got a picture of the blades? Might be a spindle on the right side or dull blades. With the right side having a diffrent type of blade doesn't make sense. Is it new to you or did you purchase it new? |
I will try to get a picture up as soon as I can. I got it a year and a half ago and never had any issue with it till now.
![]() ![]() The blade on the left hand side of the picture is the problem one. As you can see it is different than the other. the third blade is exactly like the one on the right of the picture |
Sure looks to me like the blades are double stacked. Don't think that is a good idea to do that. That set on the left most deffinately has 2 blades. I would unbolt them from the spindles and see what is going on.
and it also looks like the "good" blade is also double stacked. maybe the previous owner used old blades as a shim??? just guessing. jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716 Jeff |
Thread Tools | |
Display Modes | |
