I just bought a QA-42a for my 125 this weekend. I believe it is complete except for a lift rod. I was wondering if anyone could post a picture of a lift rod and maybe get me some measurements so I can make one for my thrower?
It's literally a rod with a 90° bend on each end, and a hole for a cotter pin. I can measure the diameter if it helps. As far as length, maybe this will help: http://www.xtrememotorworks.com/Snowblower%20Parts.html
1992 2182 with 48" deck, Kwik-Way loader, and QA42A Snow Thrower 2008 RZT 54 |
measure the length between holes and make one, easy enough.
I'd make one end adjustable, as in turnbuckle or clevis. Do you have the lift rod bracket for the 125? You will need that |
I don’t have one of those, I was planning on just making one but if there’s a place I can buy one online I’ll probably just do that
I have them available
Drop me a PM Dave S. |
Morning JoshM Here is a picture off of the QA-42 I think it is the same as the
42A but hopefully someone will clue me in if it is not. It has a few bends and even a twist, don't know if that is original or custom from before I owned it. It is made of 1/2" round stock and is 31 and 1/2 inch between the 90's. Ken |
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Should have? They were available, sure, but you can mount a QA42A to a 2182 as well. As I said in the comment you responded to, mine is a QA42A, NOT the 2-stage 451/551.
The 2182 has a smaller diameter PTO pulley which will not spin your snow thrower fast enough to work properly. I'm not saying you can't cobble it together, but it wasn't meant to be.
"Unsolicited advice is usually more about the needs of the giver than the receiver."
| Thread Tools | |
| Display Modes | |
