I just got a 719-3093 lift bracket for a future plow purchase and went to install. I noticed it is contacting the bolt heads that hold the lift bushing to the frame. This is not allowing it to be fully installed so the bolts can pass through. Is there something I am missing here?
Is that on backwards?
I am not sure how it could go on the other way since the hole on this side is not large enough and only clearance for a grease gun.
That is the correct way
Is there something else that could be causing my issue that you can see? Different screws required for the bearing, incorrectly drilled holes in the lift bracket?
Move it out about 1/8"
| Thread Tools | |
| Display Modes | |
