I have a JD plow I want to put on my 125, problem is I have no idea how it goes on. Do you use the same mount as for the mowing deck?
Thanks in advance. Mouse
1969 125 Cub Cadet 1962 Cub Cadet Orginal 2009 Cub Cadet LTX 1046 VT 1963 Cub Cadet 100 1966 Cub Cadet 122 |
They do not mount the same as the deck. Suggestion: Sell the JD blade (they are worth something to the right person) and then buy the correct blade for your 125. That way you have something that is guaranteed to work the way it should.
Is this a plow or a blade? To me, a plow is what you use to pull through the ground for gardening. A blade is what you use to move snow or dirt. If it's a blade, the only way you can make that JD "blade" work is by major modifications. If it's a "plow" then if it's for the JD integral hitch (sleeve hitch) it will work on your Cub Cadet if you have the 3 point lift and a Brinly sleeve hitch. The only group I hear use the term "plow" for a blade is Wheel Horse owners.
Thread Tools | |
Display Modes | |
