I have a NF hydraulic lift that needs to be rebuilt. Its all there, just needs to be gone thru. Is there a rebuild kit available for these units?
Mike - Ramsey, MN'65 100 - #126432 Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles "Why buy something shiny & new when you can save something old." |
I do not think so. I wish there was I have a couple on the shelf that need a rebuild.
Soo many Cubs Soo little time... Current collection: Orig. (2) 70's, 100, 71, 72, 73, 86, 108, 128, 169, 800, 1650, 1811, (those are the keepers for now) Kwickway loader, Haban Mower, #2 yard cart, IH box blade, IH york rake, IH back blade, Donnell Fork Lift attachment, Planet JR. two row planter, many brinley attachments, and of course tillers, decks, blowers and push blades. Would like to find a Viking seeder, Gannon eartcavator, other unusual attachments, and 9 speed Original. |
im sure there are other parts that will fit them. hoses and fittings and seals and stuff. i have one and i want to put new Hoses and fittings on it. since someone painted over the hoses WHICH I HATE WHEN PEOPLE DO THAT. the paint cracks and looks horrible.
I wish there was I have one I want to go thru before I install it!
Dale 147-Restored___________________882 Diesel Hydro lift (not installed)___________44" Deck 48" Deck_______________________QA-42a/b Snowthrower Rear lift ________________________XMW cat-0 rear lift Model 2 tiller____________________12" cat-0 Brinly plow |
nickvanorman-
If the paint isn't too old, lacquer thinner will probably remove it from the hoses. |
I fixed one for Mrcubcadet that was leaking around the shaft behind the pulley. There are only a couple of seals in the pump to replace. There's 1 on the shaft just behind the pulley and another on the spool that is a square o-ring but a regular round 0-ring will work. He got the seals from the Cub Cadet dealer so I don't know the part numbers.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
| Thread Tools | |
| Display Modes | |
