I have an 1811 equipped with a 42" plow blade. The tractor has wheel weights, but I notice they do not protrude out nearly as far as some I see in pictures, so I imagine they are not as heavy as they could be. I have chains, but again they do not seem as robust as others I see, at least in terms of the number of chain sections crossing the tires. So here's my issue. The tractor is fine for three or four inches of snow and maybe up to eight if the snow is light. But with deeper snow, or heavy wet snow more than four or six inches, I loose traction and have to beat at the snow with momentum. I end up spinning the wheels, wearing the chains and scarring the driveway. I made a weight box last week, which has about 100#of sand in it, but haven't had snow since to test it yet. What I'm trying to figure is can I significantly improve the traction of this tractor with more weight and better chains, or do I really need to get a bigger machine. Driveway is about 250-feet, well paved and very steep. Any thoughts? Thanks.
Put tubes in the tires and fill them with washer fluid. Part of your problem is the aluminum rear...it's about 55 lbs lighter than the cast iron rear. I have about 300 lbs on my 782 with aluminum rear and 2-link chains. You have 4-link chains. 2-link chains would help, but I'm not sure they'd make a big difference. I've found it's just about equally easy to spin tires with either type of chain on them, given the same amount of weight.
If I were you I'd start looking for a snowblower attachment. Then it doesn't matter how much snow you get because you won't be pushing it. |
![]() Quote:
MBULL
, Check the videos out in this thread. I also have a description of my set up on there to. http://www.onlycubcadets.net/forum/s...ead.php?t=8133
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
![]() Quote:
Great action pics, Bill!
I used to plow with a JD 214 with very similar setup to yours - 42" plow, bucket of sand on the back, 4 link chains. I had the same problem you do, couldn't push much, used it more as a battering ram.
Now on my 2084 I have 74# wheel weights, 2 link chains, and I put steel in my utility box (nice job building that box by the way!). It's night and day different, I can push a 54" plow with no problem. I didn't fill the tires, didn't want to be bothered if I could avoid it, and I've found no need. I only have maybe 100# of steel in the box and could add more as needed. Get some scrap steel to put in your box instead of the bucket, the weight will be low and you can double it. Then you either need the heavier wheel weights, or fill the tires, or both would be best. You'll be amazed at what it can push. |
![]() Quote:
Bill,
Thanks for the info. Nice pics! Are those hydraulic lines on the front of your rig? If so, what do you use them for? Can hydraulic lines be added to an 1811? Also, pretty sure my rear tires are 10.5" width. Do you think a narrower tire like yours gets more psi on the terrain and subsequently better traction in the snow and ice? Mark |
![]() Quote:
Saw this set of wheels on bay. The bolt pattern seems to match my hubs. Think they seem like a reasonable price given they have chains as well? http://cgi.ebay.com/EWC-23x8-5-12-Al...ht_3994wt_1135 |
Thread Tools | |
Display Modes | |
