Old 03-27-2011, 09:57 AM
BassBlaster BassBlaster is offline
Default 2165 PTO Help
New guy here. Cool site you guys have. I really like all the old Cubs you guys have brought back to life!!
Yesterday, I scored what I thought was a pretty sweet deal. I picked up a 2165 for 50 bucks. It has exactly 600 hours on it. It also came with a folder containing the manuals and every receipt from servicing so I know it was taken care of regularly. It runs perfect and everything operates just like it should with the exception of the PTO. It will not engage. It doesn't do anything. I called a dealer and asked how to tell if the switch or relay is bad or if the clutch is really bad. He said it's never the relay. My reading around here and a couple other places says different. When I pull the switch when not sitting on the seat, the safety mechanism takes over and tries to shut down the tractor so I believe the switch is good. I'll go and pick up a relay this afternoon and try that so I can rule that out. Hopefully that fixes it but wanted to know if there is something else to be looking for? If I do wind up replacing that clutch, how big of a pain is it? Thanks ahead of time for any replies.
When I get this fixed, it will only be used for mowing, no heavy work in its future. Hoping to get many years of service from it.
Old 03-27-2011, 10:14 AM
midyearguru midyearguru is offline
You got that thing for FIFTY BUCKS????
Old 03-27-2011, 12:00 PM
Yup!! I'm pretty sure its just the relay also. I just went to the auto parts store to try and get one. The guy took it apart and it was all corroded. He cleaned it up and said I think it will work. Hooked it up to a bettery with a couple test leads and nothing. Now I just have to locate one to see if thats the problem.
Old 03-27-2011, 12:55 PM
I don't think the PTO's are too bad to remove if it is like I think. If is on the bottom attached to the crankshaft, all you will have to do is remove the LONG bolt that runs up thru it into the crank. An electric impact works nicely for this. Make sure the wire plug is disconnected. It is heavy and will need support as you remove the bolt.
Old 03-27-2011, 02:56 PM
Sounds simple enough. Thanks! Hopefully I dont even get into that. I found the relay through NAPA for $14 but had to order it. The PTO is $339 through the dealer. Havnt looked for aftermarket yet. I did have to replace the battery so if this relay is the problem then I just picked up a sweet mower for about 85 bucks!! I'll feel bad if thats all it is but I guess he should have done a little research before he listed it for 50 bucks, lol.
Old 03-27-2011, 04:09 PM
bob hall bob hall is offline
Check the bearings in the pto clutch before you buy a new one. I got replacement bearings at NAPA and put them in. Although the dealer says the clutch is non-serviceable, it saved me $225.... Good Luck
